[GRASS-dev] Re: [GRASS-user] mask in PERMANENT affect on other mapsets during reprojection
Jarekj jarekj at amu.edu.pl
Mon Jun 30 00:38:43 EDT 2008
I always do as you suggest (in general other methods (with cs2cs)  in
grass are to complicated), but it not concern the problem I mentioned
Well, I found this during testing prototype of script to reproject any
raster in one step (without changing locations) so I must to know If it
is intended (for reasons unknown for me) and Script must additionally
check if no mask is present in PERMANENT or it is a bug and will be
removed in the feature
sorry I didn't add grass version: latest grass7.0 svn
Jarek
Hamish pisze:
> Jarekj wrote:
>> The situation is as follows:
>> In location GRS mapset PERMANET I have MASK (with projection of 2180
>> based on GRS elipsoid)
>> in second mapset let say jarekjaI have map which is to be reprojected to
>> other location (WGS). In that mapset no MASK is present.
>> In location WGS mapset PERMANENT  I reporject map from location GRS and
>> I have only fragment allowed by MASK from GRS PERMANENT It is intended
>> or some bug?
> side-suggestion: before running r.proj run v.in.region in the source location then v.proj from the taget location. then
>  "g.region vect=region_box -p" and check that the new resolution is ok and that rows x cols is no less than in the source region, slightly more if the reprojection rotates the box significantly. and/or try the "-n" flag with r.proj to see if that makes any help.
> Hamish
