[GRASS-user] mask in PERMANENT affect on other mapsets during
reprojection
Glynn Clements
glynn at gclements.plus.com
Mon Jun 30 10:31:04 EDT 2008
Jarekj wrote:
> So as I understand the problem will heppen when I have mask in mapset in
> source which is named as my target mapset in target location:
Correct.
If you try to reproject "srcmap in srcmapset in srclocation" to
"dstmap in dstmapset in dstlocation", the source map will be masked
with "MASK in dstmapset in srclocation", which is a bug.
In many cases, "dstmapset in srclocation" won't exist, but if
dstmapset is PERMANENT, it will.
