[GRASS-user] Problems to update with svn
Philipp Steigenberger
userlist at online.de
Sat Mar 1 07:59:26 EST 2008
Martin Landa schrieb:
> Hi,
> 2008/3/1, Philipp Steigenberger <userlist at online.de>:
> [snip]
>> >> apt-file search python-config
>> >> doesn't help
>> > see [2]
>> > `apt-get install python2.4-config` or python2.5-config based on your
>> > Python version
>> I installed python2.5 but
>> apt-get install python2.5-config
>> Reading package lists... Done
>> Building dependency tree... Done
>> E: Couldn't find package python2.5-config
>> How to get it?
> apt-file search python2.5-config
> python2.5-dev
> Martin
sometimes its so easy
configure now works.
but nevertheless another problem. Tried to include the wxwidget also.
as described at [2] http://trac.osgeo.org/grass/changeset/30171:
" --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config
with path, e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)"
I add
echo" wxWidgets/wxPython repository at apt.wxwidgets.org
deb http://apt.wxwidgets.org/ etch-wx main
deb-src http://apt.wxwidgets.org/ etch-wx main" >> sources.list
install
apt-get install python-wxgtk2.8 python-wxtools python-wxaddons wx2.8-i18n
search
apt-file search wx-config
kdevelop-data: usr/share/apps/kdevappwizard/template-common/wx-configure.in
wx-common: usr/share/man/man1/wx-config.1.gz
install again
apt-get install wx-common
but cannot find wx-config
I have
/usr/bin/wxrc
How to get wx-config?
btw man wx-config works
:o/
Philipp
