[GRASS-user] Error importing shape files
    mohannbr
    mohan_483 at rediffmail.com
    Sat Mar  1 11:35:51 EST 2008
   I use postgresql driver for GRASS. I have GRASS 6.2.2 installed in my
comp. with 'host=localhost,dbname=grass60test'.
When i try to import .shp files using v.in.ogr , i get the error...
ERROR:  invalid byte sequence for encoding "UTF8": 0xae
HINT:  This error can also happen if the byte sequence does not match the
encoding expected by the server, which is controlled by "client_encoding".
How do i correct it???
-Mohan
View this message in context: http://www.nabble.com/Error-importing-shape-files-tp15778086p15778086.html
Sent from the Grass - Users mailing list archive at Nabble.com.
