[GRASS-user] How to find out an angle between to points on the
map (for r.plane, r.lake) - shellscript
Dylan Beaudette
dylan.beaudette at gmail.com
Sat Mar 1 19:14:00 EST 2008
On Saturday 01 March 2008, Philipp Steigenberger wrote:
> Dylan Beaudette schrieb:
> > On Thursday 28 February 2008, Philipp Steigenberger wrote:
> >> Hi
> >> I want to work with r.plane and r.lake to get simulate floodings in
> >> DTMs.
> >> In the section of interest there is a river which runs from about SSW to
> >> NNE. For r.plane I need the
> >> azimuth. Is there a tool in GRASS which tells me the angle between two
> >> points I mark on the map like I can measure in between two points with
> >> d.measure?
> > Simple trigonometry is a start. Or on a computer the atan2() function is
> > useful:
> > atan2( (end_y - start_y) , (end_x - start_x) ) * 180/pi
> > attached is a patch (against todays SVN) to optionally print the bearing
> > between clicks.
> > Dylan
> Dylan,
> sorry, I have no idea how to incllude this patch to my system.
> I'm neither good in R or C or Fortran or Python.
> (Also I have problems to install the actual SVN)
> But I'm used to write shell scrpits, so I wrote this one for bc.
> #!/bin/sh
> LIST_1=`d.what.rast -t1`
> E1=`echo $LIST_1 | awk -F : '{print $1}'`
> N1=`echo $LIST_1 | awk -F : '{print $2}'`
> LIST_2=`d.what.rast -t1 --q`
> E2=`echo $LIST_2 | awk -F : '{print $1}'`
> N2=`echo $LIST_2 | awk -F : '{print $2}'`
> SCALE="scale=8"
> pi=$(echo "scale=10; 4 * a ( 1 )" | bc -l)
> echo "epsilon = `echo "$SCALE; 360-( a ( ( $E1 - $E2 ) / ( $N1 - $N2 )
> ) ) * 180 / $pi" | bc -l`°"
> echo "if epsilon > 360"
> echo "epsilon' = `echo "$SCALE; ( a ( ( $E1 - $E2 ) / ( $N1 - $N2 ) ) )
> * 180 / $pi * -1" | bc -l`°"
> In GRASS I work in Transversal Mercator (Gauß-Krüger)
> I know the script isn't perfect, cause it doesn't work if N1 = N2, but
> for me this doesn't matter.
> Philipp
Philipp,
Glad to hear that you were able to make something which worked for you. I have
submitted the patch to d.measure to the tracker, and may be integrated into
GRASS proper if it is deemed useful by the dev crowd.
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
