[GRASS-user] Checking if a point (X, Y) is inside the, polygons of a shape file using command line. Solution using R
Rick Reeves reeves at nceas.ucsb.edu
Mon Mar 3 12:35:36 EST 2008
Corrado:
This is a good task for the R programming environment, which has strong
geospatial tools and
integrates with GRASS:
Check out the following example, which solves the point-in-polygon
problem for shape files:
http://nceas.ucsb.edu/scicomp/GISSeminar/UseCases/PointInPolygonAnalysis/point_in_poly.html
Some other good examples on this site as well...
Regards,
Rick Reeves
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080303/7a1b7f40/reeves.vcf
