[GRASS-user] Update - Check points in polygons
Corrado
ct529 at york.ac.uk
Thu Mar 6 05:12:42 EST 2008
Thanks a lot to all of you!
To keep you up to date:
METHOD1
1) v.in.ogr
dsn=/home/ct529/Documents/Projects/UKBryophytes/Datasets/BRYOPHYTES/BRYOPHYTES/SSSI_vectors/ENGLAND.shp
output=England_SSSI layer=ENGLAND min_area=0.0001 snap=-1
location=England_from_shapefile
2) v.clean input=England_SSSI output=England_SSSI_clean
error=England_SSSI_error tool=bpol
3) v.in.ascii
input=/home/ct529/Documents/Projects/UKBryophytes/Datasets/species_sites_100m.csv
output=species_100m format=point fs=, skip=0 x=4 y=5 z=0 cat=0
4) in postgresql: alter table species_100m add colum sssi_name varchar(120);
5) v.distance from=species_100m to=England_SSSI dmax=0 upload=to_attr
to_column=sssi_name col=sssi_name
6) in postgresql: select species_name,sssi_name,count(species_id) from
species_100m where sssi_name is not null group by species_name,sssi_name
order by species_name;
What do you think? I may now run it on dmax=100 and dmax=500.
METHOD2
Today I am going to try Roger's method, combining GRASS and R ,so that I can
compare.
METHOD3
I would like to develop a comparative method using only grass, and reading the
shape file directly (without going through spgrass6) using readOGR and the
rgdal library. Any clue?
I think when I wrote back to the project leader that the problem was solved,
she as rather impressed by GRASS and by the GRASS community.
Best Regards
Corrado Topi
Global Climate Change and Biodiversity
Area 18,Department of Biology
University of York, York, YO10 5YW, UK
Phone: + 44 (0) 1904 328645, E-mail: ct529 at york.ac.uk
