[GRASS-user] I need help
    Philipp Steigenberger
    userlist at online.de
    Fri Mar  7 02:25:11 EST 2008
Paul Kelly wrote:
> On Thu, 6 Mar 2008, Paul Kelly wrote:
>> On Thu, 6 Mar 2008, Philipp Steigenberger wrote:
>>>>> I execute the command sh grass6install.sh
>>>>> grass-6.2.2.tar.gz_Linux_bin.tar.gz and he doesn't find the directory.
>> Can you give the exact command-line you typed, and the exact error
>> mesage (copied and pasted). This would make it a lot easier to debug.
>>> You have to unpack the tar.gz by
>>> tar xvfz grass-6.2.2.tar.gz_Linux_bin.tar.gz
>> No that's not correct. grass6install.sh is the binary installer script
> Replying to myself, sorry I missed the very weird looking filename there
> (tar.gz in the middle and at the end doesn't look right). I think
> Philipp is right and it is actually a source distribution tarball but
> has been renamed with bin in the name just to confuse things In which
> case his instructions about ./configure, make etc. apply. I'm really
> just guessing though.
> Paul
Raonel, I would suggest that you download again the actual stable version:
Here http://grass.itc.it/download/index.php
(optionally you can choose the mirror nearest to you here:
http://grass.itc.it/mirrors.php)
you can choose your distribution in the binary column. Or you download
the sourcecode and compile it by yourself (more complicated):
http://grass.itc.it/grass62/source/grass-6.2.3.tar.gz
suerte
Philipp
