[GRASS-user] Xming as X server for winGRASS?
Luigi Ponti
lponti at infinito.it
Fri Mar 7 11:47:46 EST 2008
Dear Paul,
thanks for your prompt reply.
Paul Kelly wrote:
> On Fri, 7 Mar 2008, Luigi Ponti wrote:
> A better course of action might be to try to revive the w11 driver
> (--enable-w11 configure option) which is similar but uses Windows
> functions instead of sockets. I don't know how near being finished it
> is; might be worth looking at.
The most recent thread I have found on the topic suggests that this is
still not a viable option.
http://www.nabble.com/GRASS-.-configure-options-td15482716.html#a15489963
> There's some discussion if you search the mailing lists for keywords
> like w11 and pngdriver. It isn't necessary to have the XDRIVER working
> for batch display functionality - you can use the PNG driver (in fact
> that is probably easier) and direct rendering on Windows--or on any
> other platform. See the list of PNG driver-related environment
> variables in
> http://grass.ibiblio.org/gdp/html_grass63/variables.html#png for some
> ideas on how to control it.
If anybody has a pointer to a working example that would be great. While
the concept is clear, the practicalities are not as evident by reading
recent posts on the topic:
http://www.nabble.com/why-d.vect.thematic-won%27t-run-on-WinGRASS---d.mon-problem-td15054987.html#a15054987
Particularly, how do you tell the PNG driver where to start/stop direct
rendering to png file without d.mon?
> Paul
Thanks and regards,
Luigi
