[GRASS-user] occurrence of attributes in vektortable
Tom Russo
russo at bogodyn.org
Fri Mar 7 12:20:07 EST 2008
On Fri, Mar 07, 2008 at 03:35:17PM +0100, we recorded a bogon-computron collision of the <nikos.alexandris at felis.uni-freiburg.de> flavor, containing:
> On Fri, 2008-03-07 at 08:55 -0500, Patton, Eric wrote:
> > On Fri, 2008-03-07 at 07:17 -0500, Patton, Eric wrote:
> > >>>how can i get a list of all different occurences in a column of an
> > >>>attributetable.
> > >> v.db.select map=mapname column=columnname | uniq (for vector with a connected attribute table)
> > >It doesn't work for me. What am I doing wrong?
> > Omit the -u flag from uniq.
> Hmmm? I tried but... :
> v.db.select map=TrainingSamples column=clccode_le | uniq
> clccode_le
> 3
> 334
> 3
> 332
> 334
"uniq" only prints unique lines if duplicated lines are adjacent --- so
the input to uniq has to be sorted first. The earlier example using
"sort -u" is the way to go when the input list isn't sorted, as in this
case.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
