[GRASS-user] Wich file format to "transport" (raster/ vector)
datafrom a GRASSdb in to another computer's GRASS db? Why export vector
data inshapefile for starspan/ OpenEV?
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Mon Mar 10 14:27:36 EDT 2008
On Mon, 2008-03-10 at 14:23 -0400, Patton, Eric wrote:
> >1.. if one needs to copy some GRASS raster data from his data base in
> >another computer's GRASS data base (same coordinate system of course),
> >then how? Where do for example the history files go?
> See r.pack/r.unpack in the Grass Add-ons. I use these scripts for moving
> rasters around from computer to computer:
> http://grass.gdf-hannover.de/wiki/GRASS_AddOns#Raster_add-ons
> The r.pack script uses a MatLab format file as an intermediary, and is apparently
> a decent universal format for storing rasters in.
O.K.
> >I understand (I think) the need to set-up properly a LOCATION and import
> >the data. But why isn't there a GRASS portable vector/ raster file
> >format?
> I think r.in/out.ascii and v.in/out.ascii are designed for this? Not 100%
> sure, but check the man pages for these two commands.
I am checking... It's just that I had the impression that exporting in
ascii is always a bit "dangerous" concerning the metadata this is why I
try to avoid it.
> >2. the same about vector data
> See above.
> >3. Is it really necessaty to export in shapefiles when working with
> >starspan? If there is "GRASS read-only" support by OGR why is it
> >necessary to export?
> I can't comment on Starspan; never used it.
> >What about OpenEV? If GDAL is built with GRASS support why can't it read
> >GRASS rasters?
> I've wondered how to do this as well.
> ~ Eric.
Thanks a million Mr. Patton ;-)
