[GRASS-user] Unable to import some raster and vector type maps
Marco Lechner marco.lechner at geographie.uni-freiburg.de
Tue Mar 11 15:49:35 EDT 2008
why not grabbing it from ftp://e0srp01u.ecs.nasa.gov/srtm/version2/SRTM3
and using r.in.srtm directly?
workflow:
- r.in.srtm
- r.null (may be not necessary, depends if NULL values are already set
to NULL)
- r.fillnulls (extensive but good spline interpolation to fill holes)
Marco
Nikos Alexandris schrieb:
> On Tue, 2008-03-11 at 15:17 -0300, Eric & Elga wrote:
>> Good afternoon.
> Hi!
>> After having created a new project location, I try to import SRTM3
> About SRTM: I don't know from where you have your srtm data. You can
> grab srtm3 tiles also from http://srtm.csi.cgiar.org/ (look for the SRTM
> Data Search and Download link).
> The data are provided in GeoTiFF and are projected in wgs84. So you need
> to create a LOCATION for wgs84 and impot with r.in.gdal
> (Make sure you select the "JRC" mirror to download the data if you are
> in Europe, otherwhise it's slow).
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080311/09d43f2c/marco_lechner.vcf
