[GRASS-user] Unable to import some raster and vector type maps
Marco Lechner
marco.lechner at geographie.uni-freiburg.de
Tue Mar 11 16:34:14 EDT 2008
Hi Eric,
using a RC in a productive environment is not the best way. We used the
workflow on a GRASS-course in Zürich last week using a liveDVD and GRASS
6.2.2. Well 6.2.2 has other bugs, but the srtm-import worked on a
LiveSystem with SRTM-data covering whole switzerland (16 squaredegree) -
without any problems. Well, to be honest, for the spline-interpolation
we had to decrease the resolution for the course ;-)
How about using a parallel Linux-Installation or a vmware-based
Linuxsolution?
Marco
Eric & Elga schrieb:
> ----- Original Message -----
> From: "Marco Lechner" <marco.lechner at geographie.uni-freiburg.de>
> To: "Nikos Alexandris" <nikos.alexandris at felis.uni-freiburg.de>
> Cc: "Eric & Elga" <eegaba at terra.com.br>; <grass-user at lists.osgeo.org>
> Sent: Tuesday, March 11, 2008 4:49 PM
> Subject: Re: [GRASS-user] Unable to import some raster and vector type maps
>> why not grabbing it from ftp://e0srp01u.ecs.nasa.gov/srtm/version2/SRTM3
>> and using r.in.srtm directly?
>> workflow:
>> - r.in.srtm
>> - r.null (may be not necessary, depends if NULL values are already set
>> to NULL)
>> - r.fillnulls (extensive but good spline interpolation to fill holes)
>> Marco
>> Nikos Alexandris schrieb:
>>> On Tue, 2008-03-11 at 15:17 -0300, Eric & Elga wrote:
>>>> Good afternoon.
>>> Hi!
>>>> After having created a new project location, I try to import SRTM3
>>> About SRTM: I don't know from where you have your srtm data. You can
>>> grab srtm3 tiles also from http://srtm.csi.cgiar.org/ (look for the SRTM
>>> Data Search and Download link).
>>> The data are provided in GeoTiFF and are projected in wgs84. So you need
>>> to create a LOCATION for wgs84 and impot with r.in.gdal
>>> (Make sure you select the "JRC" mirror to download the data if you are
>>> in Europe, otherwhise it's slow).
> @ nikos : The problem with CSI data is that they are not freely reusable : I
> create maps, mostly topographic ones, as hobby for the Wikipedia community
> where all media have to be placed under a free license, i.e. which can also
> be used for commercial purpose.
> @ Marco : These are the srtm and swbd I use but as I wrote, when I try to
> launch r.in.srtm or v.in.e00 they crash before opening. I'm very new with
> GRASS, is there another way to launch these modules? I'm running
> wingrass6.3RC5 : could it be that these modules use the monitor which
> doesn't work with this version?
> Thanks.
> Eric
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080311/d53b34c3/marco_lechner.vcf
