[GRASS-user] Unable to import some raster and vector type maps
Hamish hamish_b at yahoo.com
Tue Mar 11 23:18:04 EDT 2008
If you want to use GRASS on MS Windows and you don't want to deal with
developmental issues, then use the stable release under Cygwin.
All unix tools, scripts, etc will work there.
Of course we like testers for the new development releases too, just
don't expect everything to work perfectly yet :)
You may have to compile the e00conv software yourself in Cygwin if you
want to use that (maybe someone has already done it for you). It
shouldn't be too hard (./configure && make && make install).
See the v.in.e00 help page for links. AFAIK it is just a data
processing program so it probably doesn't use much in the way of
linux/unix specific things & could probably be built for windows, if a
precompiled copy isn't already available from the upstream website.
Hamish
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
