[GRASS-user] r.in.mat - How can I specify a No Data Value?
Bernhard Dobmeier dobmeier at muc.zae-bayern.de
Wed Mar 12 05:58:16 EDT 2008
Hi Tom, Hi Hamish,
thanks for your replies! The r.null setnull option was what I was
looking for. Works great!
I set the No Data Value to -9999 because i'm gonna export the data from
grass to a pollutant propagation simulation that expects -9999 as
NoDataValue by default.
For the export of the map for simulation the r.null map=mymap null=-9999
option will be the right tool.
Thanks and Cheers
Bernhard
Am Dienstag, den 11.03.2008, 14:38 -0700 schrieb Hamish:
> > Bernhard wrote:
> > > i'd like to export an elevation raster from Octave to Grass.
> > > From my available data, I can't provide a height value for every
> > > cell, so I need to use a No Data value here.
> > > The import of the .mat file works fine, as described in the
> > > manuals.
> > > Only the No Data Value (set to -9999 in Octave) isn't interpreted
> > > correctly, and that gives me an artificial "Mariana Trench" around
> > > my defined area ;)
> how did you set the No Data Value? Just arbitrarily called it -9999?
> > > Where can I set the No Data value to be used? Can I define it for a
> > > specific raster map? A standard value for the whole mapset? Or do I
> > > have to use a special value in Octave/Matlab in the first place?
> If you set those values to NaN (not a number) in Octave then r.in.mat
> should convert those to NULL. See the NOTES section of the help page.
> Or was there a problem with that?
> Tom answered:
> > I think you're looking for the GRASS program "r.null" and its
> > "setnull" option.  That will designate pixels of a specified value
> > as being NULL instead of valid numbers.
> > r.null map=mymap setnull=-9999
> Hamish
>       ____________________________________________________________________________________
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Dipl.-Ing.
Bernhard Dobmeier
Bayerisches Zentrum für Angewandte Energieforschung e.V.
ZAE Bayern
Abteilung 1 : Technik für Energiesysteme und Erneuerbare Energien
                      -Arbeitsgruppe Biomasse-
Adresse     : Walther-Meissner-Straße 6, D-85748 Garching
Telefon     : 089 / 329442-83
Telefax     : 089 / 329442-23
E-Mail      : dobmeier at muc.zae-bayern.de
http://www.zae-bayern.de <http://www.zae-bayern.de>
