[GRASS-user] Re: [GRASS-dev] db.connect database= parameter is null
Martin Landa
landa.martin at gmail.com
Wed Mar 12 11:42:37 EDT 2008
yes, see
http://trac.osgeo.org/grass/ticket/7
It seems to me that the VAR file should defined for newly created
mapset by default to avoid possible problems.
Martin
2008/3/12, Patton, Eric <epatton at nrcan.gc.ca>:
> I created a new location using today's svn source, and noticed that db.connect doesn't have its database parameter pre-populated with $GISDBASE/$LOCATION_NAME/$MAPSET/dbf as it used to; it is now blank. Possible bug? Would it possible to get the module to at least populate $GISDBASE/$LOCATION_NAME/$MAPSET for this parameter?
> ~ Eric.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
