[GRASS-user] Re: [GRASS-dev] db.connect database= parameter is null
Martin Landa
landa.martin at gmail.com
Wed Mar 12 11:54:22 EDT 2008
anyway if you run some command which calls Vect_default_field_info()
from Vlib, VAR file is created and default driver set up to dbf.
e.g. g.copy vect=
Martin
2008/3/12, Patton, Eric <epatton at nrcan.gc.ca>:
> >Hi,
> >yes, see
> >http://trac.osgeo.org/grass/ticket/7
> >It seems to me that the VAR file should defined for newly created
> >mapset by default to avoid possible problems.
> >Martin
> Thanks for the pointer. I'll hardcode my database paths for now.
> ~ Eric.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
