[GRASS-user] WinGRASS-6.3.0RC5 Self Installer + wxPython-Gui
Glynn Clements
glynn at gclements.plus.com
Tue Mar 18 04:03:09 EDT 2008
Helmut Kudrnovsky wrote:
> but during the make-process a lot of error-messages-pop-ups, especially for the vector
> modules come up .
> english-translation from a german error-message:
> "v.segment.exe could not be found - the application could not be started, because libpq.dll was not found."
You need to add the directory where the DLLs reside to the PATH
setting. Or copy the DLLs to the dist.<arch>/lib directory (or to
Windows' System32 directory).
FWIW, the above errors relate to building the HTML documentation, but
you'll get similar errors when running the programs.
> but the output from the make-process seems to be ok:
> Following modules are missing the 'description.html' file in src code:
> GRASS GIS compilation log
> Started compilation: Mon Mar 17 22:33:14 GMT 2008
> Errors in:
> /local/src/grasssvntrunk/imagery/i.class
> /local/src/grasssvntrunk/imagery/i.ortho.photo/photo.2image
> /local/src/grasssvntrunk/imagery/i.ortho.photo/photo.2target
> /local/src/grasssvntrunk/imagery/i.ortho.photo/photo.rectify
> /local/src/grasssvntrunk/imagery/i.points
> /local/src/grasssvntrunk/imagery/i.vpoints
> /local/src/grasssvntrunk/raster/r.li/r.li.daemon
> /local/src/grasssvntrunk/raster/r.li/r.li.edgedensity
> /local/src/grasssvntrunk/raster/r.li/r.li.patchdensity
> /local/src/grasssvntrunk/raster/r.li/r.li.patchnum
> /local/src/grasssvntrunk/raster/r.li/r.li.shape
> /local/src/grasssvntrunk/raster/r.li/r.li.simpson
> /local/src/grasssvntrunk/raster/r.li/r.li.shannon
> /local/src/grasssvntrunk/raster/r.li/r.li.mps
> /local/src/grasssvntrunk/raster/r.li/r.li.mpa
> /local/src/grasssvntrunk/raster/r.li/r.li.padcv
> /local/src/grasssvntrunk/raster/r.li/r.li.padsd
> /local/src/grasssvntrunk/raster/r.li/r.li.padrange
> /local/src/grasssvntrunk/raster/r.li/r.li.cwed
> /local/src/grasssvntrunk/raster/r.li/r.li.richness
> /local/src/grasssvntrunk/raster/r.li/r.li.dominance
The above modules are all known not to compile on Windows.
