[GRASS-user] v.centroids question
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Mar 19 14:07:01 EDT 2008
On Wed, 2008-03-19 at 10:20 -0700, John C. Tull wrote:
> I have a road network where I want to convert the road lines into
> boundaries, then turn the resulting spaces inside of roads into areas.
> Converting the roads to boundaries was no problem using v.type and
> v.clean tool=snap, but getting centroids into the polygons is
> trickier. Apparently, v.centroids will not add centroids to areas
> where there are boundaries that terminate inside a polygon (i.e., dead-
> end roads inside what I am hoping to turn into an area), so I end up
> with far fewer areas than I want. Do boundaries have to be contiguous
> without dangles (is that the right use of the terminology?)?
> Is there a way to get centroids into areas such as these where the
> road dangles are ignored? I don't want to drop those dead-end roads
> because they are informative, but I guess I may have to do so and then
> use v.overlay or similar at a later stage. There are also too many
> potential areas to try and manually add the centroids with v.digit.
> Perhaps there is a means in v.edit unknown to me. Any ideas or
> suggestions would be greatly appreciated. I am using GRASS 6.3rc5.
John,
maybe you could try
v.clean with type=line,boundary,centroid,area tool=snap,break,rmdupl
thresh=.01
Not sure but I suspect the "break" tool is what you might need.
