[GRASS-user] first littel experience with wxpython GUI
Martin Landa
landa.martin at gmail.com
Thu Mar 20 08:48:51 EDT 2008
to be more clear, for running GUI you need to have *write* permission
to the current mapset (g.tempfile is used, not tempfile from Python).
You can add other mapsets to the search patch from 'Config->GRASS
working environment->Mapset access'.
I hope this it helps.
Martin
2008/3/20, Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2008/3/20, Dr. Manuel Seeger <seeger at uni-trier.de>:
> > GRASS 6.3.svn (Attert_Praktikum):~ > ERROR: MAPSET Anne - permission denied
> These errors are not GUI-related, you have simply no access to this
> mapset. I will fix wxGUI not to crash. In any case you need to set up
> permissions if you want to access this mapset.
> Martin
> > GRASS_INFO_ERROR(497,1): MAPSET Anne - permission denied
> > GRASS_INFO_END(497,1)
> > Traceback (most recent call last):
> > File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1360, in
> > <module>
> > sys.exit(main())
> > File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1353, in main
> > app = GMApp(workspaceFile)
> > File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1275, in
> > __init__
> > wx.App.__init__(self, False)
> > File
> > "/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/_core.py", line
> > 7836, in __init__
> > self._BootstrapApp()
> > File
> > 7433, in _BootstrapApp
> > return _core_.PyApp__BootstrapApp(*args, **kwargs)
> > File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1291, in
> > OnInit
> > workspace = self.workspaceFile)
> > File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 157, in
> > __init__
> > self.NewDisplay(show=False)
> > File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1027, in
> > NewDisplay
> > auimgr=self._auimgr, showMapDisplay=show)
> > File
> > "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/wxgui_utils.py", line
> > 77, in __init__
> > self.Map = render.Map() # instance of render.Map to be associated
> > with display
> > File "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/render.py",
> > line 201, in __init__
> > self.mapfile = utils.GetTempfile()
> > File "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/utils.py",
> > line 41, in GetTempfile
> > "pid=%d" % os.getpid()])
> > File "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/gcmd.py", line
> > 361, in __init__
> > self.PrintModuleOutput()))
> > gui_modules.gcmd.CmdError
> > Greetings
> > Manuel
> > Martin Landa schrieb:
> > > Hi,
> > > 2008/3/18, Dr. Manuel Seeger <seeger at uni-trier.de>:
> > > [snip]
> > >> wxpython shows all mapsets present, but then crashes when I try to
> > >> access those which were created by another user. I did not see any
> > > [snip]
> > > It seems to work on my laptop, can you send me error message, traceback?
> > > Martin
> > _______________________________________________________________________
> > Dr. Manuel Seeger
> > Wiss. Assistent Scientific Assistant
> > Physische Geographie Dpt. of Physical Geography
> > FB VI - Geographie/Geowissenschaften Geography/Geosciences
> > Universität Trier University of Trier
> > D - 54286 Trier
> > Tel.: +49-651-201 4557
> > Fax: +49-651-201 3976
> > Web: http://www-neu.uni-trier.de/index.php?id=9607
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
