[GRASS-user] db_fetch questions
Moritz Lennert
mlennert at club.worldonline.be
Thu Mar 20 09:41:10 EDT 2008
On 20/03/08 14:31, Jaime Carrera wrote:
> Hi Markus and Moritz,
> Thanks for your suggestions; I tried another loop (the one from v.in.db)
> and gave the result that I needed. Below are my "experiments":
> The first db_fetch loop (exits after one interaction): I have to "cheat"
> to be able to get all the records from the database:
> while(1){
> if(db_fetch (&cursor, DB_NEXT, &more) != DB_OK)
> return(-1);
> nodeprop=db_get_value_as_double(dbvalue,ctype);
> printf("node prop= %.2f\n",nodeprop);
> count++;
> if(count<12699) /* use max(cat) value for this one, just testing*/
> more=0;
> if ( more) break;
> Now, using the loop as used in v.in.db I get what I need, without
> "cheating':
> while ( db_fetch (&cursor, DB_NEXT, &more ) == DB_OK && more ) {
> There are two differences: on the first loop more==1 immediately, and
> thus exits the loop; while on the second one the loop is exptecting
> more==1. Another difference is the != or == DB_OK part.
> What I can gather from this, is that the first loop is more appropriate
> to queries done on a category basis, but not for fetching an entire table.
I don't really understand the first one. Why do you break if more==1 ?
Instead of
more=0;
if ( more) break;
Shouldn't this just be
if(!more) break;
Moritz
