[GRASS-user] installing add-ons
Zachary zacharyparisa at gmail.com
Sun Mar 23 22:25:56 EDT 2008
The add-on I hope to install is i.topo.corr
When trying to install this (or any other add-on) either by " INST_NOW=y
make"  or the  "make MODULE_TOPDIR=$HOME/..." process as described below and
in the documentation
the process fails with:
Makefile:8: ../../include/Make/Module.make: No such file or directory
make: *** No rule to make target `../../include/Make/Module.make'.  Stop.
I have tried with compiled versions 6.3 RC5 and RC6...but get the same
results.
Any ideas?
thanks,
Zack
Massimiliano Cannata wrote:
> The grass addon (if they are in C), can be installed by re-compiling the
> source code.
> It may help this page:
> http://istgis.ist.supsi.ch:8090/pmwiki/index.php?n=GRASS.Installazione
> Once compiled the grass source code, to add an addon module just extract
> the file in the grass source directory, cd to the module directory and
> run this command: INST_NOW=y make
> Detailed informations for source compilation can be found at:
> http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_2/INSTALL
> Bye,
> Massimiliano
> Zachary Parisa wrote:
>> Hi all,
>> I have no trouble downloading the add-ons I hope to use from the
>> repository, but could use some instruction on how to get them
>> installed/functional in a 6.2.2 installation (stock Ubuntu package).
>> Thanks,
>> Zack
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Dr. Massimiliano Cannata
> Environmental & Geomatic Engineer
> Institute of Earth Scences - SUPSI
> Trevano, C.P. 72, CH-6952 Canobbio, SWITZERLAND
> Tel:    +41 (0)58 / 666 62 14
> Fax:    +41 (0)58 / 666 62 09
> E-mail: massimiliano.cannata at supsi.ch
> Web:
> http://www.ist.supsi.ch
> http://istgis.ist.supsi.ch:8001/geomatica/
View this message in context: http://www.nabble.com/installing-add-ons-tp15922472p16244490.html
Sent from the Grass - Users mailing list archive at Nabble.com.
