[GRASS-user] distance from extent to origin cost surfaces
Mon Mar 31 07:57:27 EDT 2008
Dylan Beaudette wrote:
> > > This is slightly incorrect -- as we are growing the cost surface to
> > > compute the perimeter, when we should be shrinking it. However it
> > > appears that r.grow cannot use a negative radius.
> > create a negative mask, grow that, then invert again:
> > r.mapcalc "inv_mask = if(isnull(mask), 1, null())"
> > r.grow in=inv_mask out=inv_mask.grown
> > r.mapcalc "mask_shrunk = if(isnull(inv_mask.grown), 1, null())"
> I haven't looked at the source for r.grow -- does anyone know how much effort
> it would take so that it could accept a negative "growth radius" ?
It would make more sense to add a specific "shrink" flag.
I have attached a modified (and untested) version of
raster/r.grow2/main.c which implements such a flag.
It would be possible to do so with less code duplication (the shrink
and grow cases are structurally very similar), but would might make
the code harder to understand. I'm not sure which is preferable.
 * MODULE:       r.grow2
 * AUTHOR(S):    Marjorie Larson - CERL
 *               Glynn Clements
 * PURPOSE:      Generates a raster map layer with contiguous areas
 *               grown by one cell.
 * COPYRIGHT:    (C) 2006 by the GRASS Development Team
 *               This program is free software under the GNU General Public
 *               License (>=v2). Read the file COPYING that comes with GRASS
 *               for details.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
#include <grass/glocale.h>
#define MAX(a, b)	((a) > (b) ? (a) : (b))
static int size;
static int count;
static int (*neighbors)[2];
typedef int metric_fn(int, int);
static int distance_euclidian_squared(int dx, int dy)
	return dx * dx + dy * dy;
static int distance_maximum(int dx, int dy)
	return MAX(abs(dx), abs(dy));
static int distance_manhattan(int dx, int dy)
	return abs(dx) + abs(dy);
static void setup_neighbors(double radius, int limit, metric_fn *dist)
	int i, dx, dy;
	int n;
	size = (int) radius;
	n = size * 2 + 1;
	neighbors = G_malloc(n * n * 2 * sizeof(int));
	count = 0;
	for (i = 1; i <= limit; i++)
		for (dy = -size; dy <= size; dy++)
			for (dx = -size; dx <= size; dx++)
				if ((*dist)(dx, dy) != i)
					continue;
				neighbors[count][0] = dx;
				neighbors[count][1] = dy;
				count++;
static void setup_neighbors_euclidian(double radius)
	int r2 = (int) (radius * radius);
	setup_neighbors(radius, r2, distance_euclidian_squared);
static void setup_neighbors_maximum(double radius)
	setup_neighbors(radius, (int) radius, distance_maximum);
static void setup_neighbors_manhattan(double radius)
	setup_neighbors(radius, (int) radius, distance_manhattan);
int main(int argc, char **argv)
	struct GModule *module;
	struct {
		struct Option *in, *out, *rad, *met, *old, *new;
	} opt;
	struct {
		struct Flag *q, *s;
	} flag;
	struct Colors colr;
	struct Categories cats;
	int verbose;
	int colrfile;
	char *in_name;
	char *out_name;
	double radius;
	int oldval = 0;
	int newval = 0;
	char *mapset;
	RASTER_MAP_TYPE type;
	int in_fd;
	int out_fd;
	DCELL **in_rows;
	DCELL *out_row;
	int nrows, row;
	int ncols, col;
	int shrink;
	G_gisinit(argv[0]);
	module = G_define_module();
	module->keywords = _("raster");
    module->description =
		_("Generates a raster map layer "
		"with contiguous areas grown by one cell.");
	opt.in = G_define_standard_option(G_OPT_R_INPUT);
	opt.out = G_define_standard_option(G_OPT_R_OUTPUT);
	opt.rad = G_define_option();
	opt.rad->key         = "radius";
	opt.rad->type        = TYPE_DOUBLE;
	opt.rad->required    = NO;
	opt.rad->description = _("Radius of buffer in raster cells");
	opt.rad->answer      = "1.01";
	opt.met = G_define_option();
	opt.met->key         = "metric";
	opt.met->type        = TYPE_STRING;
	opt.met->required    = NO;
	opt.met->description = _("Metric");
	opt.met->options     = "euclidian,maximum,manhattan";
	opt.met->answer      = "euclidian";
	opt.old = G_define_option();
	opt.old->key         = "old";
	opt.old->type        = TYPE_INTEGER;
	opt.old->required    = NO;
	opt.old->description = _("Value to write for input cells which are non-NULL (-1 => NULL)");
	opt.new = G_define_option();
	opt.new->key         = "new";
	opt.new->type        = TYPE_INTEGER;
	opt.new->required    = NO;
	opt.new->description = _("Value to write for \"grown\" cells");
	flag.q = G_define_flag();
	flag.q->key         = 'q';
	flag.q->description = _("Quiet");
	flag.s = G_define_flag();
	flag.s->key         = 's';
	flag.s->description = _("Shrink (grow null areas)");
	if (G_parser(argc, argv))
		exit(EXIT_FAILURE);
	in_name = opt.in->answer;
	out_name = opt.out->answer;
	radius = atof(opt.rad->answer);
	if (opt.old->answer)
		oldval = atoi(opt.old->answer);
	if (opt.new->answer)
		newval = atoi(opt.new->answer);
	verbose = !flag.q->answer;
	shrink = flag.s->answer ? 1 : 0;
	mapset = G_find_cell(in_name, "");
	if (!mapset)
		G_fatal_error(_("Raster map <%s> not found"), in_name);
	nrows = G_window_rows();
	ncols = G_window_cols();
	if (strcmp(opt.met->answer, "euclidian") == 0)
		setup_neighbors_euclidian(radius);
	else if (strcmp(opt.met->answer, "maximum") == 0)
		setup_neighbors_maximum(radius);
	else if (strcmp(opt.met->answer, "manhattan") == 0)
		setup_neighbors_manhattan(radius);
	else
		G_fatal_error(_("Unknown metric: [%s]."), opt.met->answer);
	in_fd = G_open_cell_old(in_name, mapset);
	if (in_fd < 0)
		G_fatal_error(_("Unable to open raster map <%s>"), in_name);
	type = G_get_raster_map_type(in_fd);
	out_fd = G_open_raster_new(out_name, type);
	if (out_fd < 0)
		G_fatal_error(_("Unable to create raster map <%s>"), out_name);
	if (G_read_cats(in_name, mapset, &cats) == -1)
		G_warning(_("Error reading category file for <%s>"), in_name);
		G_init_cats(0, "", &cats);
	if (G_read_colors(in_name, mapset, &colr) == -1)
		G_warning(_("Error in reading color file for <%s>"), in_name);
		colrfile = 0;
	else
		colrfile = 1;
	if (opt.old->answer && oldval >= 0)
		G_set_cat(oldval, "original cells", &cats);
		G_set_cat(newval, "grown cells", &cats);
	in_rows = G_malloc((size * 2 + 1) * sizeof(DCELL *));
	for (row = 0; row <= size * 2; row++)
		in_rows[row] = G_allocate_d_raster_buf();
	out_row = G_allocate_d_raster_buf();
	for (row = 0; row < size; row++)
		G_get_d_raster_row(in_fd, in_rows[size + row], row);
	for (row = 0; row < nrows; row++)
		DCELL *tmp;
		int i;
		if (row + size < nrows)
			G_get_d_raster_row(in_fd, in_rows[size * 2], row + size);
		for (col = 0; col < ncols; col++)
			DCELL *c = &in_rows[size][col];
			if (shrink)
				if (G_is_d_null_value(c))
					G_set_d_null_value(&out_row[col], 1);
					continue;
				for (i = 0; i < count; i++)
					int dx = neighbors[i][0];
					int dy = neighbors[i][1];
					int x = col + dx;
					int y = row + dy;
					if (x < 0 || x >= ncols || y < 0 || y >= nrows)
						continue;
					c = &in_rows[size + dy][x];
						break;
				if (i == count)
					out_row[col] = *c;
			else
				if (!G_is_d_null_value(c))
						if (oldval < 0)
						else
							out_row[col] = oldval;
					else
						out_row[col] = *c;
					continue;
					int x = col + dx;
					int y = row + dy;
						continue;
						out_row[col] = opt.new->answer
							? newval
							: *c;
						break;
				if (i == count)
		G_put_d_raster_row(out_fd, out_row);
		if (verbose)
			G_percent(row, nrows, 2);
		tmp = in_rows[0];
		for (i = 0; i < size * 2; i++)
			in_rows[i] = in_rows[i + 1];
		in_rows[size * 2] = tmp;
	if (verbose)
	G_close_cell(in_fd);
	G_close_cell(out_fd);
	if (G_write_cats(out_name, &cats) == -1)
		G_warning(_("Error writing category file for <%s>"), out_name);
	if (colrfile)
		if (G_write_colors(out_name, G_mapset(), &colr) == -1)
			G_warning(_("Error writing color file for <%s>"), out_name);
	return EXIT_SUCCESS;
