[GRASS-user] Cannot use grass on vfat partition
    Glynn Clements
    glynn at gclements.plus.com
    Fri May  2 10:51:11 EDT 2008
Agustin Lobo wrote:
> Thanks, solved by adding shortname=win95 to the mount options in /etc/fstab
> Should a bug report be filled? by me?
> Should I write a note in the wiki?
A note in the Wiki would be good, if you can figure out where to put
it.
A bug report is problematic because it isn't clear where the bug lies.
The handling of PERMANENT is a bug, but won't normally get triggered
in practice. I can't see where the incorrect test for MYNAME or WIND
lies.
