[GRASS-user] how can import ecw's in grass databse
Hamish
hamish_b at yahoo.com
Mon May 5 03:28:13 EDT 2008
> geog wrote:
> > I need to import ecw Rasters in my grass database,
> > but it won't work. (gdal not supported ecw in my grass 6.0 version)
> > What will the easiest way to do this?
> > Must I compile gdal with ecw support
H:
> yes.
I should mention that there is a possibility you can only get the ECW SDK
to work with gdal in MS Windows (??). In that case either a) try to run
GRASS with a ecw-enabled gdal in Windows, or b) use gdal_translate in
Windows to make a GeoTiff from the ECW data, and then transport the
GeoTiff back to Linux/Mac/whatever..
check for ECW support with "gdalinfo --formats"
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
