[GRASS-user] Anything new about the i.class problem?
Hernán De Angelis
dhdeangelis.listas at gmail.com
Thu May 8 05:08:06 EDT 2008
Hi all,
About one month ago there has been a discussion about a problem with i.class:
http://lists.osgeo.org/pipermail/grass-user/2008-March/043736.html
I am experiencing exactly the same problems:
- created group and subgroup (with more than 3 images)
- run i.class interactively: i.class can't locate subgroup
- run i.class from command line: generated a signature file that
cannot be read by i.maxlik
in the latter case the resulting signature file seems to be very poor,
for example:
#water
14343
#snow
485
#forest
5684
which seems odd, and signature files created by i.cluster are much
more complex than this.
Tried several times, with different locations. Always the same problem.
Is there any solution to this?
Thanks
Hernán
Hernán De Angelis
Linux user # 397217
