[GRASS-user] batch import/sql shapefiles
maning sambale
emmanuel.sambale at gmail.com
Tue May 13 03:57:31 EDT 2008
I don't think so, this one worked:
ogr2ogr -f "ESRI Shapefile" -where "ELEVATION>10" new13744-4.shp 3744-4.shp
On Tue, May 13, 2008 at 3:54 PM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
> On Tue, 2008-05-13 at 15:52 +0800, maning sambale wrote:
> > Hi,
> > This simple script doesn't seem to work on my cygwin bash
> > for i in *.shp; do
> > ogr2ogr -f "ESRI Shapefile" -where "ELEVATION>10" $i_elev $i;
> > done
> > I'm trying to extract elevation contour lines from a couple of shapefiles
> > I know it worked before on my linux.
> > cheers,
> > maning
> Maybe a problem with the "quotes" in the expression(s)?
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
