[GRASS-user] WMS fails on Geosciences Australia downloads
Richard Chirgwin
rchirgwin at ozemail.com.au
Wed May 14 06:29:18 EDT 2008
Hamish wrote:
> Richard:
>> I hope this is the last maddening issue; working with:
>> g.region n=33S s=34S w=150 e=151 nsres=00:00:05 ewres=00:00:05
>> r.in.wms -c
>> mapserv="http://www.ga.gov.au/wms/getmap?dataset=national&"
>> -g layers=dem_9sec output=dem_9sec format=png srs=EPSG:3112
>> (The small region keeps the the tile size down)
>> I get the 9-second DEM. It looks and displays okay, but the
>> elevation data is wild.
>> r.what -f input=dem_9sec at PERMANENT
>> east_north=150.8177882,-33.785157971
>> produces:
>> 150.8177882|-33.785157971||31407|
>> Since I can reasonably assume that the elevation isn't
>> 31,407 metres, nor that the elevation in the mountains
>> is lower than near the ocean, something's awry with the
>> elevation...
> I am afraid you are not looking at the elevation, but rather the color palette entry of the PNG file. ie this is a "visual only" exercise.
> WMS servers can dish up real data, but I suspect that to do that they need to support geotiff format, and the GA server only provides tiff/png/jpeg/wbmp pretty imagery. I'm not sure about that though, maybe someone reading knows better about this.
Damn, I think you're right. The TIFF, which I thought included elevation
data, seems to suffer a similar problem. Still, all is not lost, because
I can get the elevation data from a vector map of the relevant area and
create a real DEM ...
Richard
> if you look in the capabilities XML file you will see that geotiff is conspicuously missing from the available image formats:
> http://www.ga.gov.au/wms/getmap?dataset=national&request=capabilities
> If you find no joy, I'd suggest contacting Geosci Aust and asking about it; and also on the Aust-NZ OSGeo mailing list as well. There are some talented people at both places who may be able and keen to help.
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080514/02a3f92d/attachment.html
