[GRASS-user] Vdigit
Martin Landa landa.martin at gmail.com
Wed May 14 11:25:50 EDT 2008
2008/5/14 Benoit ANDRE <benoit.andre at bcgeol.be>:
>  SWIG Version 1.3.29
>  Compiled with g++ [i686-redhat-linux-gnu]
I remember I had some problems compiling wxvdigit with older versions
of swig in the past. Now I am using >= 1.3.31. Can you try to compile
with newer version of swig?
Martin
>  Le mercredi 14 mai 2008 à 16:51 +0200, Martin Landa a écrit :
>  Hi,
> > Since 6-3.0.RC06, no more possible to compile vdigit. The error message is
> which version of swig you are using?
> swig -version
> Martin
> > .[benoit at slump vdigit]$ make
> > c++
> -I/disques/linux-1/archive/GIS/grass/grass-6.4/cvn/grass-6.4.svn_src_snapshot_2008_05_10/dist.i686-pc-linux-gnu/include
> > -g -O2 -fPIC -I/usr/local/include -I/usr/local/include/python2.5
> > -I/usr/local/include/python2.5 -fno-strict-aliasing -DNDEBUG -g -fwrapv
> -O3
> > -Wall -Wstrict-prototypes
> -I/usr/local/lib/wx/include/gtk2-unicode-debug-2.8
> > -I/usr/local/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES
> > -D__WXDEBUG__ -D__WXGTK__ -pthread -DPACKAGE=\""grasslibs"\"
> > -o OBJ.i686-pc-linux-gnu/grass6_wxvdigit_wrap.o -c
> grass6_wxvdigit_wrap.cpp
> > cc1plus: attention : l'option de la ligne de commande
> "-Wstrict-prototypes"
> > est valide pour Ada/C/ObjC mais pas pour C++
> > grass6_wxvdigit_wrap.cpp: In function 'int
> > SWIG_Python_ConvertFunctionPtr(PyObject*, void**, swig_type_info*)':
> > grass6_wxvdigit_wrap.cpp:2051: erreur: invalid conversion from 'const
> > char*' to 'char*'
> > grass6_wxvdigit_wrap.cpp: In function 'void
> > SWIG_Python_FixMethods(PyMethodDef*, swig_const_info*, swig_type_info**,
> > swig_type_info**)':
> > grass6_wxvdigit_wrap.cpp:12866: erreur: invalid conversion from 'const
> > char*' to 'char*'
> > make: *** [OBJ.i686-pc-linux-gnu/grass6_wxvdigit_wrap.o] Erreur 1
> > The links /usr/local/lib/libgdi.so to
> > /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so is good.
> > I tried with various installations of wxWidget (enable or disable debug,
> > enable or disable share), without success. Any idea ?
> > Benoit ANDRE
> > Géologue - Hydrologue ________________________________
> > Bureau Conseil en Géologie
> > Rue de Leuze, 433
> > B-5300 VEZIN
> > BELGIQUE
> > Tél.: +32 81 58 26 11
> > Fax.: +32 81 58 26 12
> > Contacter...
> > Bureau Conseil en Géologie ________________________________
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
>  Benoit ANDRE
>  Rue de Leuze, 433
>  B-5300 VEZIN
>  BELGIQUE
>  Contacter...
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
