[GRASS-user] Vdigit
Martin Landa landa.martin at gmail.com
Wed May 14 17:13:05 EDT 2008
2008/5/14 Benoit ANDRE <benoit.andre at bcgeol.be>:
> RIght.
> I just installed SWIG Version 1.3.35.  Now, every thing is OK.
for now I updated README file, to require swig >= 1.3.31 for vdigit component
http://trac.osgeo.org/grass/changeset/31348
Martin
> Thanks,
> Benoit.
> Le mercredi 14 mai 2008 à 17:25 +0200, Martin Landa a écrit :
> Hi,
>>  SWIG Version 1.3.29
>>  Compiled with g++ [i686-redhat-linux-gnu]
> I remember I had some problems compiling wxvdigit with older versions
> of swig in the past. Now I am using >= 1.3.31. Can you try to compile
> with newer version of swig?
> Martin
>>  Le mercredi 14 mai 2008 à 16:51 +0200, Martin Landa a écrit :
>>  Hi,
>> > Since 6-3.0.RC06, no more possible to compile vdigit. The error message
>> > is
>> which version of swig you are using?
>> swig -version
>> Martin
>> > .[benoit at slump vdigit]$ make
>> > c++
>> -I/disques/linux-1/archive/GIS/grass/grass-6.4/cvn/grass-6.4.svn_src_snapshot_2008_05_10/dist.i686-pc-linux-gnu/include
>> > -g -O2 -fPIC -I/usr/local/include -I/usr/local/include/python2.5
>> > -I/usr/local/include/python2.5 -fno-strict-aliasing -DNDEBUG -g -fwrapv
>> -O3
>> > -Wall -Wstrict-prototypes
>> -I/usr/local/lib/wx/include/gtk2-unicode-debug-2.8
>> > -I/usr/local/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES
>> > -D__WXDEBUG__ -D__WXGTK__ -pthread -DPACKAGE=\""grasslibs"\"
>> > -o OBJ.i686-pc-linux-gnu/grass6_wxvdigit_wrap.o -c
>> grass6_wxvdigit_wrap.cpp
>> > cc1plus: attention : l'option de la ligne de commande
>> "-Wstrict-prototypes"
>> > est valide pour Ada/C/ObjC mais pas pour C++
>> > grass6_wxvdigit_wrap.cpp: In function 'int
>> > SWIG_Python_ConvertFunctionPtr(PyObject*, void**, swig_type_info*)':
>> > grass6_wxvdigit_wrap.cpp:2051: erreur: invalid conversion from 'const
>> > char*' to 'char*'
>> > grass6_wxvdigit_wrap.cpp: In function 'void
>> > SWIG_Python_FixMethods(PyMethodDef*, swig_const_info*, swig_type_info**,
>> > swig_type_info**)':
>> > grass6_wxvdigit_wrap.cpp:12866: erreur: invalid conversion from 'const
>> > char*' to 'char*'
>> > make: *** [OBJ.i686-pc-linux-gnu/grass6_wxvdigit_wrap.o] Erreur 1
>> > The links /usr/local/lib/libgdi.so to
>> > /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so is
>> > good.
>> > I tried with various installations of wxWidget (enable or disable debug,
>> > enable or disable share), without success. Any idea ?
>> > Benoit ANDRE
>> > Géologue - Hydrologue ________________________________
>> > Bureau Conseil en Géologie
>> > Rue de Leuze, 433
>> > B-5300 VEZIN
>> > BELGIQUE
>> > Tél.: +32 81 58 26 11
>> > Fax.: +32 81 58 26 12
>> > Contacter...
>> > Bureau Conseil en Géologie ________________________________
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>>  Benoit ANDRE
>>  Rue de Leuze, 433
>>  B-5300 VEZIN
>>  BELGIQUE
>>  Contacter...
> Benoit ANDRE
> Rue de Leuze, 433
> B-5300 VEZIN
> BELGIQUE
> Contacter...
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
