[GRASS-user] Problem reprojecting to UTM 34 S
Tom Russo
russo at bogodyn.org
Thu May 15 14:01:54 EDT 2008
On Thu, May 15, 2008 at 06:16:34PM +0200, we recorded a bogon-computron collision of the <r.m.krug at gmail.com> flavor, containing:
> On Thu, May 15, 2008 at 4:46 PM, Michael Perdue <michael_perdue at yahoo.ca> wrote:
> > From what I see, gdalinfo hak_ser2.asc is listing all the latitudes as being
> > positive which means that they are in the northern hemisphere. It looks to
> > me like gdal is doing the right thing and there is something wrong with the
> > ASCII grid.
That's not how I read it. The upper left corner is
> >> Upper Left ( 15.9916667, -21.9918333)
which is 15.9916667 East longitude and 21.9918333 South latitude.
> >> I have a ESRI asc raster in +proj=longlat +ellps=D_Clarke_1866 +no_defs
> >> gdalwarp -s_srs '+proj=longlat +ellps=D_Clarke_1866 +no_defs' -t_srs
> >> EPSG:32734 hak_ser2.asc hak_ser2_utm34.asc
> >> where EPSG:323734 is the definition for UTM 34 S WGS 84
I assume you mean "32734" not "323734" --- 32734 is WGS84 Zone 34 southern
hemisphere.
> >> But I get:
> >> rkrug at ecolmod1:~/Documents/Projects/AlienSpread/GIS.local/Rainer_subset>
> >> gdalinfo hak_ser2_utm34.asc
> >> Driver: GTiff/GeoTIFF
> >> Files: hak_ser2_utm34.asc
> >> Size is 1028, 880
> >> Coordinate System is:
> >> PROJCS["WGS 84 / UTM zone 34N",
> >> GEOGCS["WGS 84",
> >> DATUM["WGS_1984",
> >> SPHEROID["WGS 84",6378137,298.2572235629972,
> >> AUTHORITY["EPSG","7030"]],
> >> AUTHORITY["EPSG","6326"]],
> >> PRIMEM["Greenwich",0],
> >> UNIT["degree",0.0174532925199433],
> >> AUTHORITY["EPSG","4326"]],
> >> PROJECTION["Transverse_Mercator"],
> >> PARAMETER["latitude_of_origin",0],
> >> PARAMETER["central_meridian",21],
> >> PARAMETER["scale_factor",0.9996],
> >> PARAMETER["false_easting",500000],
> >> PARAMETER["false_northing",0],
> >> UNIT["metre",1,
> >> AUTHORITY["EPSG","9001"]],
> >> AUTHORITY["EPSG","32634"]]
That's odd --- you say you used "EPSG:32734" but this last line clearly
shows "32634" (which is WGS 84 zone 34 Northern hemisphere). Is it
possible you fat-fingered when typing in the command line?
If not, maybe you could try using the PROJ.4 specification for the
coordinate system for -t_srs instead of the EPSG number?
gdalwarp -t_srs '+proj=utm +zone=34 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs' -s_srs '+proj=longlat +ellps=D_Clarke_1866 +no_defs' hak_ser2.asc hak_ser2_utm34.asc
If that works, then perhaps there's something goofy with how GDAL is processing
your EPSG number (maybe leaving off the "+south" when it creates the proj.4
arguments?). What version of GDAL are you using?
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"It's so simple to be wise: just think of something stupid to say and
then don't say it." --- Sam Levinson
