[GRASS-user] break lines in intersection (rather category problem)
Jarosław Jasiewicz jarekj at amu.edu.pl
Fri May 16 02:51:58 EDT 2008
Hi!
Problems may seems simple but isn't
In a simple way (this is only one step there are lots of steps in the
loop): I have two lines with same category in separate file. I patch
them and make v.clean to braak them in the crossing point. Now I have
four lines with same category. I need to load lenghts of every lines to
database, (v.to.db) but:
- if I add table and load its length I have sumarrised length of 4 lines
- if I add new categories on another layer I have no way to join
information about its previous category
So I need new category for every new line to have records in database to
read its length. And I need the old category as atrribute (something
like second layer in v.to.points result)
Any help???
Jarek
