[GRASS-user] Weird Cygwin -Grass 6.2.3 issues
Manuel Francisco Maestre Páez mfmap at tragsatec.es
Mon May 19 02:50:16 EDT 2008
Thanks for the answer, but i tried checking cyggdal-1.dll and it seems it's
all ok.
I have installed all the libraries you said (and some more just in case) i
tried different versions for some of them, but... still no luck.
What can it be? I'm getting frustrated `_´
$ cygcheck /usr/local/bin/cyggdal-1.dll
C:\cygwin\usr/local/bin/cyggdal-1.dll
  C:\cygwin\bin\cygwin1.dll
    C:\WINDOWS\System32\ADVAPI32.DLL
      C:\WINDOWS\System32\ntdll.dll
      C:\WINDOWS\System32\KERNEL32.dll
      C:\WINDOWS\System32\RPCRT4.dll
  C:\WINDOWS\System32\cygjasper-1-701-1.dll
    C:\cygwin\bin\cygjpeg-62.dll
  C:\cygwin\bin\cygpng12.dll
    C:\cygwin\bin\cygz.dll
  C:\cygwin\bin\cygpq.dll
    C:\cygwin\bin\cygcrypt-0.dll
    C:\WINDOWS\System32\cygcrypto-0.9.8.dll
    C:\cygwin\bin\cygintl-3.dll
      C:\cygwin\bin\cygiconv-2.dll
    C:\cygwin\bin\cygssl-0.9.8.dll
  C:\cygwin\bin\cygtiff-5.dll
-----Glynn Clements <glynn en gclements.plus.com> escribió: -----
Para: "Manuel Francisco Maestre Páez" <mfmap en tragsatec.es>
De: Glynn Clements <glynn en gclements.plus.com>
Fecha: 14/05/2008 20:02
cc: grass-user <grass-user en lists.osgeo.org>
Asunto: Re: Re: [GRASS-user] Weird Cygwin -Grass 6.2.3 issues
Manuel Francisco Maestre Páez wrote:
> @Glynn Clements: It seems that GDAL isn't working either. gdalinfo and
> ogrinfo behaves the same way as g.remove and g.region (and many others).
> Which libraries do i need to install?
The ones which your version of GDAL requires. If you're using the
gdal-1.3.1-1 package from the GRASS site, setup.ini says that it
requires:
    requires: cygwin jasper libpng12 libpq4 libtiff5
The Cygwin installer should take care of this automatically.
But I can't guarantee that is correct; in particular, I think that it
requires jpeg62. Try running cygcheck on cyggdal-1.dll.
