[GRASS-user] Change NaN to 0 with r.mapcalc(or whatever)?
Glynn Clements
glynn at gclements.plus.com
Thu May 22 03:27:03 EDT 2008
Moskovitz, Bob wrote:
> Based on what I read from that link I tried:
> r.mapcalc "q50_eh_nonan = if(q50_eh != q50_eh,null(),q50_eh)"
> It assigned nan to 0. It would be great if r.null can use such a simple trick.
Can you try the following patch (committed to SVN trunk as r31470):
Index: raster/r.null/mask.c
--- raster/r.null/mask.c (revision 31458)
+++ raster/r.null/mask.c (working copy)
@@ -65,5 +65,8 @@
if (I->inf > 0)
return x >= I->high;
+ if (I->low != I->low && I->high != I->high)
+ return x != x;
return x >= I->low && x <= I->high;
It should allow you to use e.g. "r.null ... setnull=nan".
It appears to work, but has only been minimally tested.
