[GRASS-user] Tracing dotted lines from raster (and convert to
vector)
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Fri May 23 12:56:59 EDT 2008
> I have found that when you are working with discontinuous line segments that
> don't have gaps too large -- it is possible to "re-connect" the lines with
> the following procedure:
> 1. extract only the color of interest
> 2. use r.grow to "fatten" the segments until they touch
> 3. use r.thin to return the segments to linear feature
> 4. vectorize with r.to.vect
> I have used this approach with area features as well. See this link for some
> ideas:
> http://casoilresource.lawr.ucdavis.edu/drupal/node/244
> Cheers,
> Dylan
Yep,
it works great. Also here
http://grass.osgeo.org/wiki/Trace_vector_contours_from_a_scanned_map
which might be yours ;-)
Thanks.
It feels good that I also "found" the same way more or less in the end.
I noticed the "trick" of keeping the color of the lines of interest
afterwards.
