[GRASS-user] d.split.frame
    Hamish
    hamish_b at yahoo.com
    Mon May 26 22:34:53 EDT 2008
Nikos:
> > How do I "integrate" the d.frame.split script in grass63.1.svn, so I
> > don't need to call it from within its directory?
> Copy then in the scripts directory of GRASS!
> e.g.:
> nik at vertical:/usr/local/grass-6.3.1svn/scripts$
> cp /usr/local/src/grass-addons/display/d.frame.split/d.frame.*[rt] .
that works, but you'll have to do it again each time you install a new version of GRASS. the GRASS_ADDON_PATH method is immune to that.
Hamish
