[GRASS-user] Leics: No display in Map Display 1
H.S.Rai hardeep.rai at gmail.com
Tue May 27 04:26:50 EDT 2008
On using GRASS 6.2.2, for leics data (probably which is for GRASS 5.2
), I get first error of missing proj_info:
PROJ_INFO file not found for location leics
    while executing
"close $input"
    (procedure "MapCanvas::runprograms" line 39)
    invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
    (procedure "MapCanvas::drawmap" line 38)
    invoked from within
"MapCanvas::drawmap $mon"
    (procedure "MapCanvas::display_server" line 9)
    invoked from within
    ("after" script)
How to remove it or does it have any bearing?
In Map Display 1, I could not get display of any raster layer, however
d.mon start=x0
d.rast image
works fine i.e in Monitor X0.
How to get display in Map Display 1?
H.S.Rai
http://hs.raiandrai.com/
