[GRASS-user] help
    Patton, Eric
    epatton at nrcan.gc.ca
    Wed May 28 09:56:15 EDT 2008
>y need to make a poligon, but i make the boundary then the centroid and i
>dont know how to tell the program to make it a poligon.. can sombody help
>me? thanks a lot!!
You probably need to enable 'snapping' within the v.digit module to make the polygon
vertices coincident. See the attached screenshot showing where to set this on the
v.digit Settings.
Once you have snapping enabled, you may still have to manually move vertices that were
digitzed prior to enabling snapping. Use the 'Move point, line, boundary, or centroid'
tool on the v.digit interface (see attached screenshot). Once you move a vertex on top
of another with this tool, the two should snap an become coincident. I usually make
the snapping parameter around a few tens of meters for projected (UTM-style) projections.
~ Eric.
Type: image/png
Desc: Screenshot-settings.png
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080528/c1850e9e/Screenshot-settings.png
Type: image/png
Desc: Move_Boundary.png
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080528/c1850e9e/Move_Boundary.png
