[GRASS-user] Trouble with v.db.join and sqlite
Markus Neteler
neteler at osgeo.org
Fri May 30 09:17:13 EDT 2008
On Fri, May 30, 2008 at 1:17 PM, doktoreas <thedoktor78 at gmail.com> wrote:
> Markus Neteler OSGeo wrote:
>> Luca,
>> can you replicate this with Spearfish or the NC data set?
>> Then we could easier test things...
>> Markus
> Hi Markus,
> those are the steps to replicate the problem with NC dataset ( all is done
> in a new mapset called sqlite):
> db.connect driver=sqlite
> database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
> g.copy vect=urbanarea at PERMANENT,urbanarea
> v.extract -t input=urbanarea output=urban_point type=point,centroid
> v.db.addtable urban_point
> v.db.join map=urbanarea column=cat otable=urban_point ocolumn=cat
> DBMI-SQLite driver error:
> Error in sqlite3_prepare():
> duplicate column name: cat
> ERROR: Error while executing: 'ALTER TABLE urban_point ADD COLUMN cat
> INTEGER
> ERROR: Cannot continue (problem adding column).
> ERROR: Cannot continue.
> Thanks for your help
Like this it was easy to replicated.
(Hopefully) fixed in 6.4.develbranch and 7.trunk.
You can grab the fixed script also here:
http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts/v.db.join/v.db.join
(download at page bottom)
Markus
