[GRASS-user] Problems with compiling
Fri May 30 15:58:46 EDT 2008
Miha Staut wrote:
> Recently I have upgraded my system to Fedora Core 9. Running the
> configure script on a fresh 6.3.0 download did not report any problems
> but make did not compile any modules at all. Errors are too numerous
> to post them on the mailing list and trying to interpret them by a
> definite non-expert did not help a lot.
Post the first few errors (the actual error messages from the "make"
output, not the directories from error.log).
Often, a key library (e.g. libgis) will fail to compile, so everything
which requires that library fails to link.
