[GRASS-user] Re: Help: Converting a raster map between locations (from wgs84 lat / long to UTM)
Sat Nov 1 00:33:55 EDT 2008
Sebastian P. Luque wrote:
> On an "additional" question: How do people set the resolution
> correctly when transforming from lat/lon to meter and vice-versa?
There is no "correct" resolution when re-projecting rasters; whatever
you choose, the conversion will be "lossy" to some extent. It's just a
question of what's adequate for your purposes.
