[GRASS-user] sites library vs. GRASS 6 vector library - trhematic map in NVIZ
Maris Nartiss maris.gis at gmail.com
Sun Nov 2 11:56:24 EST 2008
Hello Tomas,
I just tested recent 6.4 svn version. Sites warning is not harmfull. I
was able to change point color/size without problems.
NVIZ may have problems due to OpenGL implementation issues. It may not
be GRASS related.
Maris.
2008/11/2, Tomas Lanczos <lanczos at t-zones.sk>:
> Hello everybody,
> I created a point vector map by importing a table from a postgres
> database using v.in.db. When I tried to prepare a 3D thematic map in
> nviz I got the following errormessage:
> "Adapted sites library used for vector points (module should be updated
> to GRASS 6 vector library)."
> This happened using Grass 6.3 built from source in Ubuntu Hardy. I tried
> also 6.4 SVN and 7 SVN, built from source as well. Few weeks ago  the
> thematic map request in nviz it caused closing NVIZ with the same
> errormessage.When I tried last svn I got only black spheres on points,
> the nviz continued by without thematic colours. I am a bit confused by
> this errormessage, I tried to find out in the help whether I will find
> something for conversion, but did not succeed. What I'm doing wrong?
> regards
> Tomas
> p.s.: here is a grass configure script I am using to compile grass:
> ./configure --with-tcltk-includes=/usr/include/tcl8.4 \
> --with-freetype --with-freetype-includes=/usr/include/freetype2 \
> --with-readline --with-cxx --enable-largefile \
> --with-motif \
> --with-postgres --with-postgres-includes=/usr/include/postgresql/ \
> --with-postgres-libs=/usr/lib/postgresql \
> --with-python \
> --with-cairo \
> --with-wxwidgets --with-blas \
> --with-proj-share=/usr/share/proj/ \
> --with-gdal-config=/usr/bin/gdal-config
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
