[GRASS-user] v.select output vector is empty
Moritz Lennert
mlennert at club.worldonline.be
Wed Nov 5 04:07:34 EST 2008
On 04/11/08 17:57, Kevin Webb wrote:
> Thank you for your reply Hamish.
> 2 questions based on your suggestion...
> At 11:18 PM 10/29/2008, Hamish wrote:
>> Kevin Webb wrote:
>> > I am attempting to execute a "point-in-polygon" process on 2 vectors
>> using
>> > v.select and the output vector is empty, it contains no value/s.
>> most likely one of both of the inputs is missing category numbers.
>> if areas do not have centroids you should add them with v.centroids.
>> In general add cat numbers to features with v.category.
> Your suggestion to use v.category worked, v.select on the output vector
> from the
> v.category command yielded a result.
> 1.) Why does a 'cat' column show in both vectors but v.select doesn't
> work until
> v.category is executed?
> Both vectors have the 'cat' column and a visual check of the contents of
> the
> attribute tables for both vectors show a cat value for all records.
Just because there is a cat column in the attribute table does not mean
that the actual features have category numbers. To check that you can
compare the output of v.category option=report ("count" column) with the
output of v.info -t.
Moritz
