[GRASS-user] inner and outer buffer for a boundary
Otto Dassau
otto.dassau at gmx.de
Wed Nov 5 08:46:16 EST 2008
Hi Moritz,
On Wed, 05 Nov 2008 14:25:24 +0100
Moritz Lennert <mlennert at club.worldonline.be> wrote:
> On 05/11/08 13:46, Otto Dassau wrote:
> > Hi,
> > I tried to create a bufferzone (inner and outer area) around an area
> > boundary
> > using following steps (reproduced with spearfish quads data):
> > # change boundary to line
> > v.type input=quads output=quadsline type=boundary,line
> > # remove centroids from line map
> > v.edit map=quadsline type=centroid tool=delete cat=1-3
> > v.build quadsline
> > Erzeuge Topologie ...
> > 3 primitives registriert
> > Building areas: 100%
> > 0 Flächen erstellt
> > 0 Inselflächen erstellt
> > Füge Inselflächen hinzu:
> > Füge Zentroide hinzu: 100%
> > Die Topologie wurde erstellt.
> > Anzahl von Knoten : 2
> > Anzahl von Primitives : 3
> > Anzahl von Punkten : 0
> > Anzahl von Linien : 3
> > Anzahl von Boundaries : 0
> > Anzahl von Zentroiden : 0
> > Anzahl von Flächen : 0
> > Anzahl von Inseln : 0
> > Now I tried to buffer the lines, but v.buffer does not recognise there are
> > lines (and not boundaries) available in the quadslines file:
> > v.buffer in=quadsline out=quadsbuffer buffer=1000
> > Toleranz in Karteneinheiten: 10
> > Lines buffers...
> > 100%
> > Areas buffers...
> > Building parts of topology...
> > 0 primitives registriert
> > Anzahl von Knoten : 0
> > Anzahl von Primitives : 0
> > Anzahl von Linien : 0
> > Anzahl von Flächen : -
> > Anzahl von Inseln : -
> > Is this a bug or do I need another step, so v.buffer finds the existing
lines
> > and buffers correctly? When I export the quadslines to a line shape and
import
> > again, v.buffer works as expected.
> Sounds like the lines do not have category values associated to them
> (which is done automatically during import), so you probably need to run
> v.category, before running v.buffer.
yes, adding categories to the lines before v.buffer works..
thanks a lot
Otto
