[GRASS-user] Rename multiple sqlite columns at once
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Nov 5 09:17:23 EST 2008
On Tue, 2008-11-04 at 10:35 +0100, Paolo Craveri wrote:
> Hello Nikos
> > The command
> > v.db.renamecol map=test_rencol column="AREA","area"
> > does not work. I assume that trying to use 'tr' for example wouldn't
> > help (?). Or am I doing something wrong?
> Try this:
> #!/bin/sh
> # # # in this example I use nc_spm_07 dataset
> # # # I created a sqlite mapset
> db.connect driver=sqlite \
> database='$GISDBASE/$LOCATION_NAME/$MAPSET/my_sqlitedb.db'
> db.connect -p
> g.copy vect=hospitals,myhospitals --overwrite
> v.db.connect myhospitals -p
> db.columns myhospitals
> # use awk, function: tolower
> # echo "MINNIE" | awk '{print tolower($1)}'
> # minnie
> # ...and function substr
> # echo "minnie_tmp"| awk '{print substr($1,1,length($1)-length("_tmp"))}'
> # minnie
> #skip out duplicate column name error
> # (no differences between lower and upper case)
> key_field="cat"
> suffix="_tmp"
> #THIS MAY TAKE A WHILE...
> for field in `db.columns myhospitals`; do
> if [ "$field" != "$key_field" ]; then
> tmpfield=`echo $field | awk '{print tolower($1)}'`
> tmpfield=$tmpfield$suffix
> v.db.renamecol map=myhospitals layer=1 column=$field,$tmpfield
> lower_field=`echo $tmpfield $suffix| awk '{print
> substr($1,1,length($1)-length($2))}'`
> v.db.renamecol map=myhospitals layer=1 column=$tmpfield,$lower_field
> fi
> done
> there are same better and more elegant solutions probably...
> ciao
> Paolo
Ciao Paolo!
Looks like a nice learning-example to me :-)
It works!! But still I get some error/warning from "v.db.renamecol".
Don't know, I changed it a bit... :
#!/bin/sh
key_column="cat"
suffix="_tmp"
for column in `db.columns test`; do
if [ "$column" != "$key_column" ]; then
tempcolumn=`echo $column | awk '{print tolower($1)}'`
tempcolumn=$tempcolumn$suffix
v.db.renamecol map=test layer=1 column=$column,
$tempcolumn
lower_column=`echo $tempcolumn $suffix| awk '{print
v.db.renamecol map=test layer=1 column=$tempcolumn,
$lower_column
fi
done
db.columns test
The error is:
Sorry <_tmp> is not a valid option
Grazie mille, Nikos
