[GRASS-user] More maps with same legend (for visually compare)
Hamish hamish_b at yahoo.com
Sat Nov 8 22:13:55 EST 2008
Bornemisza Imre wrote:
> > The problem is, that the scaling
> >  and coloring of surfaces is different by each map.
> > Is it possible to set with a parameter of v.surf.rst that
> >  all maps legend should have use the legend
> >  with the same highest and deepest point?
> > I don't find so a parameter.
> > Is there another solut ion to visualize the time series?
Moritz Lennert:
> This is not a v.surf.rst issue, but a r.colors issues. You
> can either create a customized color table in a file and use
> r.colors rules= to apply these rules to all your maps, or,
> if you have one raster map which is the reference map, you
> can also use r.colors raster=
added as a wiki FAQ:
 http://grass.osgeo.org/wiki/Time_series#Common_legends_for_many_raster_maps
Hamish
