[GRASS-user] gdal-grass plugin
Tue Nov 11 14:19:49 EST 2008
Jarek Jasiewicz wrote:
> yes I'm little unclear
> Problem is with new qis ( G_no_gisinit error) I found on goolge solution
> that I must recompile gdal without grass, next compile grass and grass
> plugin
> The question is:
> I I'd like to install grass-plugin and latest version I found on:
> http://www.gdal.org/dl/  is 1.4.3
> so:
> 1) I can install gdal-grass plugin 1.4.3 on gdal 1.5.3
> 2) I must downgrade gdal to 1.4.3 (seems rather stupid idea)
> 3) there are is gdal-grass plugin 1.5.3 on the other locacation differ
> than http://www.gdal.org/dl/
> I ask because I have working gdal-grass instalation and I dont want to
> destroy it.
Jarek,
Note that generally speaking you can build the gdal-grass 1.4.3 plugin
against GDAL 1.5.3 just fine.
Best regards,
