[GRASS-user] 2 important broken wiki-links
    Markus Neteler
    neteler at osgeo.org
    Wed Nov 12 16:39:21 EST 2008
On Wed, Nov 12, 2008 at 9:08 PM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
> I am looking for a centroid definition (how is it calculated exactly)
> and found some links in the wiki:
> http://mpa.itc.it/markus/grass63progman/Vector_Library.html#background
... leads to
http://download.osgeo.org/grass/grass6_progman/Vector_Library.html#background
which is broken since for a couple of weeks the Vector Library isn't
build any more on grass.osgeo.org.
I have no idea why.
see
-> vector: Vector_Library (GRASS Vector and Direct Graph Library)
Try in the main source code directory:
make htmldocs-single
it should build also the Vector_Library docs (lib/vector/) but on the server it
fails for unknown reasons. Does that work for you?
Markus
