[GRASS-user] Rename multiple sqlite columns at once
Dylan Beaudette
debeaudette at ucdavis.edu
Tue Nov 18 20:07:38 EST 2008
On Tuesday 18 November 2008, Nikos Alexandris wrote:
> On Tue, 2008-11-18 at 15:12 +0100, Nikos Alexandris wrote:
> > On Sat, 2008-11-15 at 23:53 -0800, Hamish wrote:
> > > Hi,
> > > I haven't really been following this thread (or know much about it),
> > > but I spotted this tip on the gdal site, maybe it helps:
> > > http://www.gdal.org/ogr/drv_gpx.html
> > > # Use of -sql option to remap field names to the ones allowed by the
> > > GPX schema !
> > > ogr2ogr -f GPX output.gpx input.shp -sql "SELECT field1 AS name, field2
> > > AS desc FROM source_layer"
> > > Hamish
> > Hamish,
> > sorry for not following up. I've tried your suggestion and there was
> > some error. I can't provide details now (working in another machine).
> > I'll do so later... :-)
> # trying with a grass-vector
> ##(following the example & terminology used in the page "drv_gpx.html")
> ogr2ogr -f "ESRI Shapefile"
> befliegung_test.shp
> /geo/grassdb/rlp_fgaps/gk2_opt6_test/PERMANENT/vector/befliegung/head -sql
> "select AREA AS area, PERIMETER AS perimeter from
> /geo/grassdb/rlp_fgaps/gk2_opt6_test/PERMANENT/vector/befliegung/head"
> ERROR 1: SQL: Missing comma after column AREA in SELECT statement. ## I
> don't think that a comma is required after the "field" name
> I get the same ERROR when trying on a shapefile.
> Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Yeah... I have had the error before as well. Was using GDAL-trunk.
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
