[GRASS-user] wxGUI label
    Moritz Lennert
    mlennert at club.worldonline.be
    Fri Nov 21 08:44:13 EST 2008
On 21/11/08 12:00, Paolo Craveri wrote:
> Hi all
> In wxGUI I'm trying labelling but not labels appears at all.
> e.g.: archsites (spearfish60 location)
> The command line reported at the bottom is (see image at
> http://picasaweb.google.it/pcraveri/WxGUI#):
> d.vect map=archsites at PERMANENT type=point,area,centroid,line,boundary
> attrcol=str1 llayer=1
> but no labels are rendered in map display.
> The same with areas, lines, etc.
> Where I'm wrong?
Did you tick the 'attr' check box in the Optional tab ("Display"
parameter) ?
Moritz
